Seal 54 Base Heat Assist Laminator
MrDesignGuy
Our shop just received a Seal 54 Base Heat Assist Laminator and I am just learning to use it. It's a pretty basic laminator that's very easy to use. I am trying to use the Heat Assist function. The manual says to allow ample time for the Upper roller to heat up to 40C before using. I've had the heat turned on for about 30 minutes now and detect no change in temp to the touch. Any thoughts on what "ample" time means or how long most roller take to heat up? Any help on the matter would be appreciated.
John
darrellcarpenay
Seal 54 base laminator troubleshooting
seal 54 base laminator doesn't move in snail mode or regular forward or backward - check blown fuse and replace
