Serial vs USB Connection
captainron19
So I have an old JSI Cutter - JSIP24 that I believe is mimicked off of the Creation CTN630
Anyway..... have to get a new PC and wanted to get an All in One and I have always used a serial port but All in Ones do not come with a serial port and not sure if I can even install one on there. Has anyone ever been involved with a similar situation and used a serial to USB adapter and did it work ok?
timgo
Graphics Designer
You can use your JSI Cutter - JSIP24 with any PC with any Windows version. But your software driver must be compitable with your windows version.
captainron19
Currently using Windows 10 and it works fine with that.... not a concern - was just curious about the serial to USB Adapter
bannertime
You'll be fine as long as you get a decent one with accessible drivers. Tripp Lite and Cables To Go are pretty popular. I picked up one from Amazon by a company called Cable Matters. I think it's rebranded but it's been flawless for about a year now. Runs a 60in plotter on a 20ft serial cable off Windows 7. You may have to go from db-25 to db-9 to usb.
