Sign Blanks
CanuckSigns
do you have any way of cutting these from a 4'x8' sheet? it's going to be much cheaper to cut them from a sheet of PVC, a good knife and safety ruler should do it.
You could cut them with a paper cutter and then stack them, tape them all together and push them up against a disc sander for your corners. Either pre-mark the top panel or use a jig.
