Question Software to cut different layers
First post!
I have a Summa S2 T160 cutter and I was curious if a software exists that would allow me to cut with different settings on each layer. As far as I can tell this cutter only supports kiss cut and flexcut modes. I would like to be able to specify the cutting force and other settings of each layer of a design. For example if I had a design that was just three lines I would want force 150 on line 1, 300 on line 2 and 600 on line 3. Right now with winplot I can only specify kiss cut or flexcut on each line.
Thanks!
EDIT: CoCut had the ability.
AF
Winplot can do this by assigning colors to paths and then adjusting the cutter before cutting each color.
I would assume any rip can do this automatically. I know Colorgate can do this. It is a rather basic task. Maybe I am missing something with your question?
FrankW
Flexi would let you assign different settings to different colours, and - since v19 - to layers too.
Jgowxio
First post!
Thanks!
I suggest you try EasyCut Pro software, it is suitable for a variety of cutting machines, it has two versions of windows and mac platform, very easy to use.
