Solaris Inks - weigh your 440 cartridges
Discussion in 'Digital Printing' started by RocketBanner, Jun 19, 2012.
  1. RocketBanner
    RocketBanner Member
    62
    Solaris is shorting their inks, but don't take my word for it, weigh them yourself (see the procedure below)
    I tried Solaris Inks a couple months ago. This is the 4th non-OEM ink I have tried. I have never had good results with 3rd party inks so I was a bit Leary, but when LiqueColor offered to sell them to me direct for $54 for a 440 cartridge I could not resist. I always weigh my inks from a new vendor to make sure I am not getting ripped off. My results are that every 440 cartridge of Solaris ink is short 50-80 milliliters.
    Here's how to test for yourself without opening a cartridge. Weigh your cartridges full then load them and use till the tab pops, then use a syringe with an ink needle to remove the unusable ink remaining in the cartridge (usually 20-30 ml) Then weigh exactly 10cc of the ink to get the specific gravity of the ink, (it varies a little by color but is usually around .97, you can use this number as an average if you don't have a scale accurate enough to weigh in tenths of a gram) Now take the difference in weight of a full cartridge to that of a completely empty cartridge and divide that number by the specific gravity (or .97 if you like) You'll discover the cartridges are far short of the 440ml that is suppose to be in there.
    I am back on OEM inks and have asked LiqueColor for a refund. I have been told that because I "tampered" with the ink cartridges I would not be given a refund. Tampered? pulling out the unusable ink from an empty cartridge destined for the garbage is tampering?? Oh Please.
    I encourage people to please do this simple test and post your results here.
  2. CS-SignSupply-TT
    CS-SignSupply-TT Very Active Member
    1,541
    1
    Hey RocketBanner, were you buying direct from LiqueColor or were you buying from a distributor; which distributor?
  3. J Hill Designs
    J Hill Designs Major Contributor
    15,549
    15
  4. RocketBanner
    RocketBanner Member
    62
    I bought direct from LiqueColor in Norman OK. I just looked up my invoice and I actually only paid $51.95. My sales person was Laurie
  5. CanuckSigns
    CanuckSigns Very Active Member
    3,019
    252
    83
    Nov 11, 2008
    Ontario
    sounds like you got what you paid for. Personally i'm too busy running a business to bother weighing empty ink carts to ensure I don't get "ripped off" of $1.50 worth of ink.
  6. ChicagoGraphics
    ChicagoGraphics Major Contributor
    4,763
    51
    48
    Feb 27, 2007
    World
    I never could understand if someone switches to a 3rd party ink why bother with the cartridges, why not just get a bulk system.
  7. SightLine
    SightLine Very Active Member
    Because the majority of bulk systems are problematic and ultimatley lead to problems..... Only the newest generation of bag type sealed bulk systems are truly problem free. Even aftermarket cartridges are still a pretty huge savings over most OEM cartridges.
  8. RocketBanner
    RocketBanner Member
    62
    your arithmetic is way off
  9. J Hill Designs
    15,549
    15
    yeah more like between $4 and $9 (as long as your 'tried and true' weighing method is in fact 'true') but yeah. still not at all worth it
    are you sure you aren't taking into account the bag etc?
  10. really?
    i used bulk in system on 4 different machines for over 10 years and had ZERO problems....
  11. CanuckSigns
    3,019
    252
    83
    Nov 11, 2008
    Ontario
    Yes it was, still the point is valid, in the amount of time you spend weighing carts, calculating specific gravity of inks, and going back and forth with the supplier over $10 worth of ink, you could have made some signs and put more than $10 in your pocket.
  12. ICeMAnAbk
    ICeMAnAbk Member
    95
    Ya, we gotta measure the vinyl rolls and make sure we got 150ft in a 50yd roll. How the heck are we gonna weigh ink too? :wink:
  13. RocketBanner
    RocketBanner Member
    62
    I have no idea what your talking about, I don't weigh every cartridge, I weighed a sample of cartridges one time to check the integrity of a new vendor.
    I will say this though, under normal operations Everytime I change a cartridge I will spend 30 seconds pulling $10 worth of ink out of it and injecting it into it's sister cartridge. For me that's about $200/week of ink I would otherwise throw out with the spent cartridge.
    Put that in your pipe and smoke it.:clapping:
  14. RocketBanner
    RocketBanner Member
    62
    I don't know about you but I don't like getting ripped off.
  15. Jack Knight1979
    Jack Knight1979 Very Active Member
    1,083
    2
    38
    Jan 23, 2008
    Maine
    I've used solaris for years. Not one problem. I buy in liter bottles though. hard to short you off on a clear liter bottle.
  16. Mike Paul
    Mike Paul Major Contributor
    5,437
    8
    38
    Dec 30, 2003
    NJ
    The difference is probably the ink used for cleanings...
    Do you weigh the drained ink container too?
  17. RocketBanner
    RocketBanner Member
    62
    The inks being short was not the only problem I had with these inks for the 2 weeks I had them in my machine, but it was the most blatantly dishonest.
    These inks are too viscous, you need to push them thru your machine constantly or your heads will clog. I always leave my machine turned on over the weekend so it will run periodic cleanings. Even with this the heads would have several dropouts when I would come in on Monday, this never happens with OEM inks. I had a problem with ink starvation and over spray with the black ink, way worse then with the OEMs. I blew a black print head 2 days after switching to Solaris inks. The head had 3.5 billion counts, too few for the head to quit.
    Other than that they were great.
  18. J Hill Designs
    15,549
    15
    I wouldnt consider problem after problem for 2 weeks 'great'
  19. RocketBanner
    RocketBanner Member
    62
    huh? I am just trying to determine how much ink was in the cartridge when it was sealed up and shipped to me as a supposed cartridge containing 440ml of ink. How do you do that? well, again, You take the weight of the full cartridge, minus the weight of the empty cartridge and the difference is the weight of the ink that was in there when you put the new cartridge in your machine...who cares about the cleanings...irrelevant. I just want to know that I am getting the 440ml of ink I am paying for...and if you're buy Solaris you're not...that simple.
  20. J Hill Designs
    15,549
    15
    how much was that black printhead, and did you save enough buying the cheap ink to justify getting a new one?
  21. CanuckSigns
    3,019
    252
    83
    Nov 11, 2008
    Ontario
    Nevermind, I just had a look at your website, at the prices you are selling banners to the general public for, I can see why every penny counts.
