solvent to dye sub
1leonchen
Good day. Hope all is well. And you are safe.
I have too many solvent printers and want to convert one to dye sub inks. which machine would be the easiest to do a conversion roland sp 300, or mutoh 1324. i need to replace heads in both machine soon and was considering the conversion. your input is greatly appreciated.
Noble Haus
you can go Dye sub to solvent but NOT solvent to Dye Sub UNLESS you change out ALL the lines
netsol
noble haus
i would not have necessarily thought that was true.
i wouldn't think changing the lines is the end of the world
netsol
i believe ink owl has a se of conversion cartridges for the wide format epsons.
it seem "it's easier to get there from here" with the large format epson ultrachrome printers
or so they claim
