Source for LED strips
WhiskeyMike
Hello, new user here, long time reader. Hopefully this is the right place to post this.
I'm trying to source an LED strip that is able to be bent laterally/horizontally. Vast majority of LED strips on the market bend great vertically (up and down with the strip), but I can't find anything that will bend into a 15" circle (diameter), about 45" circumference while the LED strip faces up/outward from the bend. In case it matters, I'm looking for 12v and red.
I've found "Angel eyes/Halo's" that are affixed to a hard plastic backing, but the largest size I've found is 60 or 120mm which is well short of what I need and can't be modified.
Thanks for your help.
Mike
WhiskeyMike
Thanks! That would work if I could solve the 12v-24v issue. 12v is already provided to this sign, so I'd really like to stay with that without adding additional complexity. I'll use these terms to see if I can find something similar.
Oh, I should have mentioned this earlier, but I'm looking for weatherproof rating with either ip66/ip67.
letterman7
For applications like that, typically individual pucks are used, not a strip. All you'll need to add is something to support the pucks.
