SP540v - Spot color inconsistant across media
LA Cameras
When I am printing a spot color (or any not spot color as well), There will be a shift in color from left to right on the print. The right side (as I am looking at the printer) is darker than the left. Its not a lot but the projects I'm doing I have to piece panels together to make a larger graphic and it can be very noticeable depending on the color and lights on the wall.
John
CanuckSigns
when printing panels, there is an option in versaworks called "flip alternated" which flips every other panel 180 degrees so the sides that line up are always printed on the same side of the machine for this exact reason.
LA Cameras
I have been overlooking that option. I'll give that a try. Thanks!
