Speed of BN-20 silver ink
mkubiniok
Hi
Is here someone who has a BN-20 and can tell me the speed print when you use Silver ink? I have heard that it is 10cm/hour. Is that right?
Welder.man
I just printed 1m of metallic decals and it took 167 minutes, very slow but I just let it print while I do other things.
mkubiniok
Ah ok. Seems to be faster than 10cm. :) again one question. If you print maybe an image, 50cm long, and in the middle of the image is only a 5cm long area with Metallic, does the printer print the rest of the image in the same slow print mode or does he print the non-metallic areas faster??
Welder.man
I have not tried that yet but I have seen in versaworks I can tick return to origin after print so I guess I could print the cmky first and than go back and print the metallic separately later.
Maybe someone else may know more
