Summa 75 plotter help!!!
SUNBURST
SUMMA 75 cutter HELP.....
The plotter when finished cutting a job stops and then if you try to send another job its scrolling back to the begining point and starts cutting there and cuts overtop of what was already cut!!! I would think this is a simple issure to resolve but be dammned if I can figure this out!! Does anyone know how to fix this, I have searched through manuals, changed the settings in the computer etc etc.....:banghead:
FrankW
I don't know which software you use but in most softwares you have the possibility to set a setting like "advance after plot". When this is deactivated the plotter will start every job from the same origin ... activate it and the plotter will plot each job after the other.
