Summa S2 160 Opos Cam Uneven Cutting Depth
Discussion in 'Summa' started by Digilab2, Jun 12, 2019.
  1. Digilab2
    Digilab2 New Member
    13
    Aug 8, 2011
    Mexico
    Hello,
    I recently purchased a Summa S2 mainly for Flexcut Stickers, the problem is that the plotter is cutting uneven but only on the right side of the plotter( is not cutting trough ), I first made a coil setup but then I realized that if I manually push down the blade holder the Nosepiece do not touch the cutting strip (See the visible gap in the picture), but only on the right side, If I repeat that in the center or on the left side of the plotter the Nosepiece touch the cutting strip.
    My theory is that the cutting strip is defective, thinner on the right side or maybe the chasis of the plotter is factory defective.
    See the attached pictures.
    Any thoughts would be greatly appreciated.
    Thank you!
    Eduardo
  2. solarprotect
    solarprotect New Member
    3
    Apr 27, 2015
    Kaštela, Croatia
    Change the strip, problem solved
    • Informative Informative x 1
  3. Digilab2
    Digilab2 New Member
    13
    Aug 8, 2011
    Mexico
    Hello,
    I removed the strip and only changed the adhesive, problem solved. Now the cut is even.
