Summa S2t Cutting Reflective Issues
mgieske
Anyone got a trick for print/cut on reflective? We have a 160S2T and Onyx12. Tracking is always off. Has a lot of trouble finding registration marks. Our non reflective cuts perfectly.
PHILJOHNSON
Sales Manager
Hi Mgieske,
Are you cutting engineer grade reflective, prismatic reflective, or diamond grade reflective? How long of a cut are you attempting to do? If you are cutting longer than 4 feet do you have paneling turned on? What about your velocity setting?
Best regards,
Phil Johnson
Summa Inc.
Split76
cut black registration marks from vinyl and apply?.. My summa F doesn't find reg marks from diamond grade but it can be manually accepted from camera view. I have onyx 12 too.
Bly
I've never needed to do it but believe you can darken the rego marks in Onyx.
There's a setting somewhere..
SignMeUpGraphics
Super Active Member
Is that the one you're referring to?
  • Agree
Reactions: Bly
FrankW
Try to calibrate media to improve the marker recognition. It's in the OPOS menu. For that, print a black rectangle of about 5 x 5cm. The cutter will read the black area and the background area and will calculate a contrast value. And will warn if the contrast can't be calibrated.
