summa s2t - flex cut question
Quark
can the Summa's s2t flex cut option (cutting all the way through the paper liner) be used in a heavy sticker production environment? flex cutting 200-300 of few inch x few inch stickers day in and day out? or is it more of a low volume specialty option that is more hassle to use than not? I'm fine replacing blades once every few weeks as long as it is reliable and quality process.Thanks all
Behrmon
Pr. Bear-Mon
We flex cut hundreds a week with no issues with ours. I do try and push sheets of say 25 up on the small stuff if the customer is applying them to something themselves.
jerry369
if you make frequent use of FlexCut consider using a double edge knife (code 390-551), it's a more wear resistant knife
