Summa T series 160 not connecting
I have 2 t series S160 plotters. Last month 1 quit cutting and says" Could not open Summa Socket Cutter" Today I went to cut some vinyl and the other machines does the same thing.. The machines run off ethernet connections, on 2 different hubs in the work area.. I pinged the ip address and both address sent and received. Does anyone have any way to correct this? I'm waiting on Summa tech support to call back but have work that needs to get out...
balstestrat
Problem Solver
Does it do it all the time or randomly?
Check that all cabling is properly attached and no damaged.
Try cutting with some other PC like laptop and plug that cutter straight to it.
Try USB.
Bly
Cutting to our S2T is like that.
Reboot the cutter, Winplot/Barcode Server even the PC to get it cutting.
It's a feature!
