Question summacut d60 stopped cutting
George SOS
Please help someone!!! I have owned a Summacut D60 vinyl plotter for about 15 years now. Yesterday It starting cutting and then suddenly the pouncing tool in the tool carriage stopped going up and down for the knife to have contact with vinyl although it continued to act as it were cutting the letters but in mid-air. Although the plotter start and feeds ok, accepts the job from software, the pouncing tool won't go up and down to cut. I changed knife still the same won't actually cut down on vinyl. Can someone please let me know if there is a quick fix for this problem.
FrankW
Maybe the knife holder is loose (does the bracket moves up and down)?
Otherwise it looks like that you need a new head or a new head cable.
George SOS
When I move the knife holder manually with my fingers it moves up and down but it won't move up and down when I do test cut.
George SOS
FrankW
I had the idea that it perhaps move up and down, but wont cut because of the tool is too high. But when you say that the bracket dont move, that will not be the problem.
I would buy a new head cable, and if this wont work a new cutting head. Specially with a new cutting head, it could be that a repair would be more expensive than the value of the cutter, so I would think over buying a new one.
George SOS
George SOS
Thank you very much for your assistance. I will buy a new head cable to see if it works. Thank you for your time and effort.
