Summacut D75 question
GVP
Hi, Does anyone know - is there a way of adjusting the amount of feed after the job has cut? At the moment, the tail end of the job doesn't quite clear the slot that you can run the razor-blade trimmer along - we have to manually move it forward to clear it on each job. I can't seem to find anything in the manual.
decalman
I got a D75. They didn't even give me a manual.
I can't figure out how to adjust setting for a piece. The roll setting eats up about 3 feet , so I'm stuck with a 6 foot piece of Oracle 951, unable to use it for what I need. I couldn't find the help number online.
jerry369
If you are using the Feed option in Winplot (or after an OPOS job), it uses the "Recut Offset" parameter of the plotter to set the distance of the new origin from the last cut.
