test
Signs101Admin
Owner
Staff member
X Specifications
  • Motors: 4-T-Motor U8II
  • Propeller size: 29”
  • Weight: ~14.5 lbs. / ~6.5 kg
  • Max payload: ~8.7 lbs. / ~3.9 kg1
  • MTOW: 37 lbs. / 17kg
  • Power: 16Ah to 44Ah @ 44v1
  • Flight time: ~10 – 45 minutes1
  • Control range: ~5 miles / ~8 km
  • Max speed: 65 mph / 100 km/h
  • Dust & water-resistant
  • Power plant(s) 1,000 hour TBO
  • Maximum thrust ~64 lbs. / ~29 kg
X8 Specifications
  • Motors: 8-T-Motor U8II
  • Weight: ~19 lbs. / ~8.6 kg1
  • Max Payload: ~15 lbs. ~6.8 kg1
  • MTOW 2: 25+ lbs. / 11 kg
  • Flight time: ~10 – 35 minutes1
  • Control range: ~ 5 miles / ~8 km
  • Maximum thrust ~128 lbs. / ~58 kg
Additional Specifications
  • Diagonal Wheelbase: 1,200mm
  • Autopilot: Pixhawk 2.1 / CUBE, Orange (Made in Taiwan)
  • FPV Video: High Definition FPV Video
  • Ingress Protection: Water & Dust Protected (IP Testing In Progress)
  • Ground Station Controller: your choice of radio
  • External Power: 5v, 12v, 24v, 50v
  • External Communications: SBus / Serial
  • External Video: Supported through external HDMI Connector
Signs101Admin
Owner
Staff member
test
