The secret of spot welding technology for automotive aluminum alloy plate
Discussion in 'Vendor Shout Out' started by guojianbin, Sep 4, 2020.
  1. guojianbin
    guojianbin New Member
    1. Welding point penetration depth: the welding point penetration depth cannot exceed 10% of the aluminum alloy plate thickness.
    2. Requirements for welding nuclei: After the workpiece is welded, the workpiece must be subjected to a tensile test or a pull-through destructive test. The firmness of the workpiece is required. After the workpiece is pulled through, the nucleus must be more than 8 mm, otherwise it is regarded as welding Unqualified.
    3. Welding pores and welding cracks: After the welding is completed, the welding part of the workpiece should be tested in section, and the solder joints must not have pores and cracks.
    4. Macroscopic test of solder joint profile: After the solder joint is subjected to the profile test, the macroscopic test is followed, and the welding nucleation contact surface of the workpiece is required to be no less than 30% of the plate thickness. And the range between 30%-90% is considered qualified.
    5. The solder joint requirements are spherical: this requirement is for the electrode, and the electrode contact surface is required to have a small arc.
    To meet the above technical requirements, it is necessary to achieve reasonable coordination of various parameters of the welding machine and precise welding equipment.
  2. GAC05
    GAC05 Major Contributor
    5,930
    790
    113
    Dec 27, 2005
    Guam USA
    OK
    • Like Like x 1
    • Hilarious! Hilarious! x 1
  3. JBurton
    JBurton Signtologist
    1,823
    361
    83
    Sep 28, 2017
    Arkansas
    1. If it doesn't look like a stack of dimes, you're doing it wrong.
    2. ???
    3. Profit!
    Also, what's an aluminum suppiler?
  4. Notarealsignguy
    Notarealsignguy Active Member
    974
    252
    63
    Feb 20, 2020
    Florida
    I love when people tell you they can weld followed by "it may not be pretty but it's strong"
  5. guojianbin
    thanks
  6. signage
    signage Major Contributor
    9,517
    75
    48
    Oct 5, 2005
    Penn
  7. GAC05
    5,930
    790
    113
    Dec 27, 2005
    Guam USA
  8. Johnny Best
    Johnny Best Very Active Member
    3,423
    1,915
    113
    Dec 9, 2015
    buffalo ny
