Thick lines in Illustrator are wire thin in Flexi
Texas_Signmaker
Very Active Signmaker
I have a logo that has some thick lines that show up correctly in Illustrator, but when I import it into Flexi they are really thin.
Is there a way to retain the thickness when importing into flexi?
SignMeUpGraphics
Super Active Member
Sorry, was away for the weekend... yes, expand in Illustrator it what I meant. Turns lines into objects which should have the effect you managed to achieve :)
Evan Gillette
If you transfer as an eps they should keep their stroke width. You can always change the stroke on them in flexi, or expand before saving as mentioned.
Bobby H
Arial Sucks.
In Adobe Illustrator I almost always use the Path Offset tool to generate outline effects around source objects. It avoids the double inline/outline paths when expanding line strokes.
