Tiling a graphic for a cut across the width of your media?
SignProPlus-Chip
When I try and cut multiple copies of a single graphic in Flexi (Pro 8.1) it puts the copies in a row down the length of the media. This wastes a lot of vinyl. Is there a way to get it to tile the copies across the width instead? I swear I have done this before, but at the time the hardware was different, so I was also wondering if it's a limitation of my little Roland GX24?
mnapuran
I've not seen that problem if there is sufficient width on the material. Have you tried rotating the design in production manager?
J Hill Designs
just set up the width multiples ... you can do the length repeats in the prod. mgr.
to answer your question, I have that happen to me sometimes, and i just fiddle with center/left/right justification and the panel margins, and it usually corrects it
GAC05
Quit buggin' me
This fixes it in 8.6 as well. I always double check a file if I am running it a second or 3rd time. The copies can suddenly change into a long string of singles down the material without doing anything other than opening the Production Manager.
If this does not fix it post up a screen grab of your Production manager window with the problem showing.
wayne k
guam usa
