Tiny label / decal for fishing rods
threedog
Just wanted to know what is recommended for tiny fishing rod decals.
I have a customer that wants Gold decals made as the rod builder.
What material do you recommend?
Thanks for the help.
T
threedog
Do you own a printer or are you just fishing?
I have a versacamm vp540. I do a lot of banners and lager decals.
I have not made anything this small, or printed / cut this small.
What material would you recommend ? and size cutting blade?
SightLine
If its a large quantity than as Visual mentioned, outsource it to a place like Stouse. Otherwise something like an Edge print with a small cutter would be ideal. You "could" print them with your big Roland but use this analogy, sure you can put finishing nails in trim work with a 40lb sledgehammer but is that really the ideal hammer for the job?
GB2
Old Member
I think it would depend a lot on exactly what the artwork looked like. Gerber Edge printing is most likely the best way.
woolly
All depends what you call tiny but you could be surprised how fine it can print.
Also Will it be lacquered over
Bill Modzel
I used to print decals for a buddy who built fly rods. I printed them on the Edge on .001" clear polyester with deluxe gold foil which is a gold/chrome. It's not recommended for exterior use but generally, it gets buried in the clearcoat on the rods and holds up well. . . at least it did on the 9wt gloomis that he gave me for my birthday many years ago.
