Transluscent Vinyl to lexan.
mudmedia
Any tips on mounting translucent printed vinyl with 290 over laminate 3'x18' to lexan for a back-lit sign?
If I start it and then mount it using a laminator will it track straight enough for 17 ft?
MikePro
do it all the time with my laminator. just make sure your panel doesn't have any jagged edges that will damage the rollers and you're set.
i've been known to add guiderails to my laminator for my longer runs, for piece of mind and easy loading.
applicationwise, checkout youtube videos for "rolls roller" for inspiration.
thmooch
On that size I would "hinge" 1/3 using a "Big Squeegee", then turn around and do the other 2/3. Dry.
mudmedia
been hearing a lot of "big squeegee" but have not looked into one is it worth buying for this one project? Can I use it even if I do it wet?
