Trouble with AE-60 Elite
Hi, im new here, pardon my poor english, i was wondering if someone knows how to calibrate a AE-60 Elite i been having trouble with the cuts (text are cut rounded) and somebody tell me the problem is the calibration, thanks in advance!
CS-SignSupply
Possibly offset.
This menu allows you to change the tool offset which is automatically set when you select the tool. You should only change this setting only to improve the corner cutting quality with a dull blade. Note: if you select the tool after changing the offset, the preset offset will take placed.
Press the left key on the keypad to decrease the tool offset.
Press the right key on the keypad to increase the tool offset.
Press the enter key on the keypad to confirm the tool offset you have selected.
Press the up key on the keypad to go to the previous menu function.
Press the down key on the keypad to go to the following menu function.
Press the menu key on the keypad to return to the jogging menu.
