Trying to mill halfway through 1 inch PVC on a Kongsberg
M@CK
Hey gang, I'm trying to make a countersink on a one inch PVC, and I cant seam to figure out how to make the router not got all that way trough the material. I tried specifying a thiner material, but that machine automatic measurement is overriding me. Here are the settings I'm using:
Anny help greatly appreciated.
Here are my settings:
M@CK
Your depth is 0?
Yep it was ! so changing the depth to say .5 inch will cause the machine to only cut to half an inch ?
The tech that "trained" me told me this was if your tool height isn't low enough you can go in the minus here and fake a deeper cut.
Christian @ 2CT Media
-12 or -12.2 in your depth field will do what you want.
Caliper your pvc as mm then divide by 2 and make it a negative number. Positive will push it in to the table or spoilboard. The icon shows you negative is off the surface and positive is into the surface.
DaveD
What Kongsberg machine are you running? Can I pick your brain on it?
M@CK
Hey DaveD !!!! Sorry i dint see your post sooner ! its an i-XL24 and bee my guest, ask away, If I cant answer maybe an other member can.
