UPS for 220v
nomadme
Hey guys!
How do you guys handle battery backup UPS for 220v HP Latex machines?
I feel like I need to get one, but it seems to be hard to find a UPS equipment with 220v out.
SightLine
I doubt you will find any at your local Best Buy store if that is what you are asking. You will likely need to order one. There are literally tons of options for UPS's with high voltage outputs and inputs. We have three Eaton 9130 UPS's in a rack (along with 9 extended battery modules) which all are 240v input and all have both 240v and 120v outputs. We do not even have HP printers either. That being said "most" modern electronics are dual voltage and also generally, slightly more efficient when run on the higher voltage as well. Our Mimaki's, cutter, servers, network equipment, RIP, and several other things are all run at 240v from the UPS's.
