US Cutter replacing Roland PNC 960
Discussion in 'Roland' started by osman, Apr 23, 2010.
  1. osman
    osman New Member
    11
    Guys,
    I was earlier having rolan PNC 960. but it is creatign problems now and i could not solve it..
    I am now thinking to change my plotter to US cutter
    here is the link i m thinking to buy :
    http://www.uscutter.com/USCutter-MH...tter-Desktop-model-WITHOUT-STAND-_p_1335.html
    but i want to know that would it work directly with Corel Draw or not using the print option for sign making?
    I also want you reviews about this machine!
    I do not hav much $ in my pocket right now and cant afford a ROLAND.
    and also if i import it to Pakistan i think i would hav to pay 100 percent customs duty.. either roland or US cutter..
    so please help me!!
    thnx
    Osman
  2. Techman
    Techman Major Contributor
    8,520
    8
    38
    Jun 24, 2003
    michigan
    us cutter is a chinese cutter
  3. osman
    osman New Member
    11
    how z it in running n working if u use it 4 professional purposes??
  4. CES020
    CES020 Very Active Member
    2,875
    4
    38
    Oct 16, 2008
    VA
    You get what you pay for. Don't expect a professional quality, heavy duty, industrial designed machine for a bargain.
  5. Compilla
    Compilla Active Member
    733
    Creation cutters are NOT GOOD!
  6. axgillette
    axgillette Member
    97
    I don't suggest getting a Chinese cutter. There is nothing like a Roland to tell you the truth. If you search around i am sure you can find parts to fix your Roland that you have right now.
  7. OldPaint
    OldPaint Major Contributor
    WASTE OF MONEY...........after owning a ROLAND. you will not be happy!!!!
  8. osman
    osman New Member
    11
    OK dudes !!
    I ll try to fix it somwhere from any printer repairing personnel.
    I ll post a lik shortly of a vdo i hav made of the problems i m facing if you could see and tell me what the problem could be!
  9. osman
    osman New Member
    11
    http://www.youtube.com/watch?v=vh9UM_tJhig
    http://www.youtube.com/watch?v=F6Jio2gRb84
    these r the 2 vdos i hav made while trying to make sign using a pen at the paper.. bcause i do not want to waste vinyl and blade.. as i knw it is not working accurately!!
    It sometimes cut completely ok specially when EEROM is cleared using right left and origin key!
    Please help me if you can or give me any professional guys cell no or email who could help me in this case!
    thanks a lot for all of your support guys..
    Osman
  10. Techman
    8,520
    8
    38
    Jun 24, 2003
    michigan
    the cut speed is way too high.. can you slow it down ?
  11. osman
    osman New Member
    11
    yes i hav tried slowing down the speed using a switch at side.. but it didnt worked out!
  12. OldPaint
    THE SLIDE SWITCH ......is for down pressure. look in the setup for cut speed or IPS!!
