Using Corel as cutting software
gt350ed
First, I apologize if this inquiry is being placed in the wrong forum. If it is, I'd appreciate further direction.
I have a Graphtec CE3000-40. I use Corel 9 and 12 daily in conjunction with my laser. I have been told that I can use Corel as my cutting software without a "bridge" or "plug-in".
If this is true, I would be grateful if someone could provide me with specifics as to set-up. I have tried doing searches throughout Signs101 and all I've come up with so far are fragments of information, as opposed to detailed "here's how you do it" instructions.
Thank you.
OldPaint
1st you need to run the plotter from its PRINTER PORT CONNECTION.....to the COMPUTER PRINTER PORT (LPT-1)
contact graphtec for the driver.......if you are capabel of running corel.....then the set up is easy....call me 1 850-944-5060 .........i do cut from corle to ROLANDS...
Jackpine
Thank you.
Graphtec CE3000-40, there is a bridge program from Graphtec that should have came with the cutter. It is a decent program once you get it set up for basic cutting. Check Graphtec web site if you don't have it.
