Versa Camm question
Discussion in 'Roland' started by roxym, May 15, 2006.
  1. roxym
    roxym Member
    174
    I'm thinking of getting a VersaCamm and am a bit comfused about what software is needed. The salesman told me that I needed FlexiPro or something equivalent to drive the printer, is this so? I currently have a PC600 and export my CorelDraw files as an EPS, open in ColorChoice and away it goes. If I do indeed need a bridge program, what do you people suggest?
    Sorry for the dumb questions, just don't want to spend money needlessly. Thanks!
  2. High Octane
    High Octane Active Member
    923
    13
    18
    Mar 27, 2005
    Fenton, Michigan
    The Versacamm comes with the rip software...all you need to do is export the eps file from corel to the supplied Versaworks rip and you're good to go...no need for Flexi.
  3. roxym
    roxym Member
    174
    Thanks for the help. So....was the salesman pulling my leg and just trying to make an extra sale ya think? He said I couldn't go from CorelDraw to the printer and he has me confused. (That's not hard unfortunately)
  4. Barry
    Barry Active Member
    659
  5. roxym
    roxym Member
    174
    Barry-I am looking at a 30", can't afford the larger one right now. Would you care to pm me and give me the details? Thanks....
  6. roxym
    roxym Member
    174
    Duh, nevermind. Just went to your link.
  7. 2NinerNiner2
    2NinerNiner2 Very Active Member
    1,122
    Mar 21, 2006
    Calgary, AB
    Barry - is Versaworks really that poor? I have had absolutely no problems with ColoRIP that came with my old SP-300.
  8. Barry
    Barry Active Member
    659
    Versaworks can really limit a lot of the settings on your printer and Roland really tries to lock people into their more expensive medias & ink with it. Things that are simple in ColorRip (Like print/laminate/cut) become more difficult in versaworks.
    If you have no other Rip to compare with then you will probably think Versaworks is OK, but if you have used a decent Rip you will understand why dealers are pushing things like Flexi.
    Your one of the lucky ones with ColorRip. ColorRip is Wasatch SoftRip re-branded. If you buy the full version of Wasatch SoftRip your looking at about $3,500.
  9. 2NinerNiner2
    1,122
    Mar 21, 2006
    Calgary, AB
    Thanks Barry :) ...wow, I had no idea the Wasatch RIP was that expensive! Guess that explains why some refer to Versaworks as 'VersaWorst' :)
