VersaCamm Cutting problems
Discussion in 'Roland' started by Mason, May 15, 2007.
  1. Mason
    Mason Very Active Member
    2,037
    Aug 11, 2005
    SP 300V is not making complete contour cuts.
    The cutlines look like dashed lines, not completely cutting, Ive changed the blade, adjusted cut pressure both up and down, reduced the "up speed" all to no avail.. anyone got any suggestions aside from my idea of blowing a hole in it with my 12 gauge..
  2. Gino
    Gino Premium Subscriber
    33,122
    2,260
    113
    Jun 7, 2006
    PA
    Is it consistantly the same dotted configuration ??
    OR​
    Does it do it in certain areas more than others ??
  3. Baz
    Baz Very Active Member
    Could be the teflon strip (on the printer under where the blade cuts) that needs to be replaced.
  4. tmac
    tmac Member
    144
    use the 12 gauge, I wish Roland would give us a service manual
  5. customsticker
    customsticker Member
    145
    Change out the blade holder if the protection strip doesn't look worn.
  6. cinemasign.grafix
    cinemasign.grafix Member
    469
    Aug 14, 2005
  7. Mason
    2,037
    Aug 11, 2005
    It does it in certain areas more than others..
  8. Gino
    33,122
    2,260
    113
    Jun 7, 2006
    PA
    I believe your ink is too wet while cutting.... causing it to ever-so-slightly bunch up and not get a clear cutting surface. The ink sometimes softens the media to a point where we get some crazy cuts also. It's especially annoying at inside corners. Jusy keep your knife handy. :wink:
  9. ChicagoGraphics
    ChicagoGraphics Major Contributor
    4,812
    59
    48
    Feb 27, 2007
    World
    Forget fixing it, make a video of you blasting it with your shot gun LOL
  10. Mason
    2,037
    Aug 11, 2005
    That would be good but Im not printing, just cutting..
  11. Gino
    33,122
    2,260
    113
    Jun 7, 2006
    PA
    Now try the 12 gauge solution. :Oops:
  12. Urban Image
    Urban Image Member
    252
    I let my wife carry the 12 guage. Pick up an 8 or a 10 and go at it.
  13. threeputt
    threeputt Very Active Member
    3,389
    1
    38
    Mar 10, 2006
    washington state
    That eight will walk ya back a step or two.
  14. Mason
    2,037
    Aug 11, 2005
    Blade holder, theres a bearing inside the thing that the blade rides in, **** the bed.. new holder, cuts like a charm..
  15. customsticker
    145
    Yep! Glad I could help :)
  16. Mason
    2,037
    Aug 11, 2005
    Yup, you called it
  17. canadianchef
    canadianchef Member
    110
    Jan 15, 2006
    Try This !
    I had the same thing happen to me and I found out that a little speck of dirt that gets in where the blade sits in the holder will cause the same result. Use a a little WD 40 or some light oil (like 3-1) and lubricate the blade. This is done by turning the blade holder upside down and putting a few drops inside around the blade.
    This fixed my problem with the same issues that you explained.
    Many Thanks !
    Terry:Canada 2:
  18. customsticker
    145
    First check the blade, which is generally obvious when the lines aren't getting through the vinyl, or are tearing the vinyl instead of cutting it.
    If you are dealing with the skipping issues, or the problem where the vinyl isn't making turns, or is even not cutting in some places, the protection strip is worn, or the blade holder is shot.
    Protection strip first, since its obvious. YOu can't always tell whenever the blade holder is worn out by eye or even by feel (by twisting the blade inside the holder).
  19. DRamm76
    DRamm76 Member
    496
    1
    If you've changed the blade and it's still not cutting properly, and only cutting in sections with dashes it's probably the blade holder.
