vg540 help
tim99
VG 540 drained cleaning solution in the wiper blade tray. however on refilling i cannot get past the set/change cleaning solution screen..
cleaning solution bag is about half way full. in the off chance it wasn't enough i replaced with a new bag and still getting the same issue.
any ideas here?
tim99
ya i attempted that.
upon power up on the display screen - wiper try is not filled ( i press enter) -change cl-liquid for wiper (pull out cleaning cartridge replace with new one) - change cl-liquid for wiper
it doesn't even try to fill.
tim99
just to update this. i performed a pump up and somehow that solved everything... anyways back up and running again. Thanks for your help Mainframe
Mainframe
Your welcome for the help, what is a pump up? Is it something you can select on the machine? I have never heard that one. just curious in case I need to do it on my machine.
tim99
ya pump up basically empty's the lines and dampers of ink then refill's them. wastes quite a bit of ink doing it. you can access it though the service menu
