Vinyl Cutting
Discussion in 'Newbie Forum' started by mollracing, Apr 2, 2008.
  1. mollracing
    mollracing New Member
    8
    If you have image larger than your plotter can cut how can you split it up. I have a GX-24 but the image I want to cut will be 42 inches tall.
    Thanks racer77
  2. cOrKinSA
    cOrKinSA Very Active Member
    2,242
    2
    What software are you using?
    In Flexi you can do it in your Production Manager.
  3. mollracing
    8
    im using corel x3
  4. Techman
    Techman Major Contributor
    8,520
    8
    38
    Jun 24, 2003
    michigan
    panel it
    If you get cocut pro it will do it for you..
  5. mollracing
    8
    can you explain panel it
    I have corel x3 and studio cut that came with my gx-24
    Not really looking to buy a high dollor s/w
    Thanks racer77
  6. ChiknNutz
    ChiknNutz Major Contributor
    4,789
    2
    Of course not...
  7. Raulrdz
    Raulrdz Member
    248
    Mar 27, 2007
    Brownsville, Texas
    Here's the way you panel a garphic.
    Create a vector file, get in the car, drive to a sign professional near you... and they will know exactly what to do.
  8. mollracing
    8
    I did not think my request was off the wall. Was only asking a simple question with out spending any money if I did not have to.I was unsure if the s/w I allready have would do the trick or not.
    racer77
  9. Raulrdz
    Raulrdz Member
    248
    Mar 27, 2007
    Brownsville, Texas
    Just ribbing you this is a basic question, which one assumes a sign shop or even hardcore hobbiest already knows. The s/w that came with your plotter may have the feature, if not I don't know of any other way than shelling out some money for s/w you can also try Signcut X2 it has a subscription based feature.
  10. Sign Works
    Sign Works Very Active Member
    1,548
    65
    48
    Nov 25, 2006
    Sacramento, CA
    If you do not have software that has paneling capabilities within it's cut/plot section then simply panel the artwork manually within your chosen vector design program, a simple task that takes all of about 5 seconds if that, do not forget to create/compensate for an overlap.
  11. mollracing
    8
    thanks for the info
  12. Mike Paul
    Mike Paul Major Contributor
    5,438
    8
    38
    Dec 30, 2003
    NJ
    I see you have a SP300v so you should have Versaworks. Why not panel it with the overlap in Versaworks and cut it on your VersaCamm?
  13. RedWolf
    RedWolf Member
    184
    Feb 7, 2008
    Bowler
    Raulrdz,
    Not everybody uses the same exact software that you do. I use basically the same thing that mollracing uses except my Corel is version 12. So I was actually watching the thread for usefull info also. Not saying I wont ever need to use it, I have not had the need to cut anything bigger than 24" yet. IMO not a thing wrong with somebody asking this question, we are all here to try and help each other.
    Matt
  14. signage
    signage Major Contributor
    9,517
    75
    48
    Oct 5, 2005
    Penn
    You could also do a search for paneling and it would tell you what it is and how to do it. If not once you know what it is it should be that difficult to figure out. jm02c
  15. OldPaint
    OldPaint Major Contributor
    can be done, but hard to explain in type.....i do it all the time in corel.
  16. fastcut
    fastcut Member
    499
    Easier said than done...if you don't know it's called paneling then you wouldn't know what to search for.
    I just zoom in tight as possible in my design software, cut that artwork right in half, plot it as two seperate pieces and overlap it. I'm sure it's not the proper way but it's gotten the job done more than a few times. I'm glad I know it's called paneling, now I'll go see if I can't learn something new.
    :thankyou:
  17. D&Tgraphics
    D&Tgraphics Very Active Member
    2,222
    3
    38
    May 17, 2007
    Lockport, NY
    Here's what I don't get. When I started out, I didn't have a signs101 to go to for answers. I didn't have anybody to go to for any answers. I just got in the software, thought about what I had to do and figured out a way to do it. Just get in there and experiment. That's the only way your going to learn.
    Doesn't anybody do any work anymore and use their brain to figure things out?
    I had the same problem once that your having now, and well, I gave it a little thought, and it didn't take long, and I figured out a solution. Just stop and think.
  18. Raulrdz
    Raulrdz Member
    248
    Mar 27, 2007
    Brownsville, Texas
    I second that!
  19. Techman
    8,520
    8
    38
    Jun 24, 2003
    michigan
    Thats the problem. People get low end stuff,, and come here for free tech support answers. The easier it gets and the more info stored here the more the noobs expect info to be handed to them.
    They don't wish to spend any cash to get the tools that will do the job. Cocut Pro is not a high end software. Its a package that every one should have at a minimum.
  20. weaselboogie
    weaselboogie Very Active Member
    3,835
    9
    38
    Apr 23, 2006
    Us
    There's about 5 ways to do it!
    Good luck!
