Vinyl Express GRC61 plotter driver
ABCDecals
ABCDe-Cals
Can anyone help me? I want to just hook my laptop to the cutter but I don't know where the Driver for the USB cable is.
I do have a call into SignWarehouse.
thanks
Kevin
Jim Doggett
Hi Kevin,
I seem to recall that the GRC-61 USB is not supported and that you need to connect via serial or a USB to serial adapter.
I'll double-check with our support in the morning. But I think that might be the issue.
Best,
Jim
strypguy
Jim is right. I have that model. I use a serial port. I have also tried the serial to usb but it randomly lost the connection so I went back to serial port only.
Nice little cutter though, it's been a good worker for me since 2002.
John
Tony McD
I'm on my second GRC-61 cutter and it's hooked up usb.
First one was struck by lightening.
Mine is hooked up to xp with a serial to usb converter cable that
I got from signwarehouse.
It has worked fine for about eight years with no problems.
I'm also using LXI 6.6 v1 software with usb dongle.
I did have to download a usb hasp driver, so the computer would see the dongle.
You might ask signwarehouse about the serial-usb converter cable.
Works fine for me.
mpa1971
Hi Kevin,
We recommend using a Keyspan brand USB adapter for this type of connection.
We stock and sell the Keyspans. I pasted a link below to an article on the support website (www.signwarehouse.com/support) below that has instructions on how to set the Keyspan up once you have it:
http://www.signwarehouse.com/support/index.php?_m=knowledgebase&_a=viewarticle&kbarticleid=116
You can contact sales or order the Keyspan from support at (800) 966 - 1783. You can also email support directly at support@signwarehouse.com if you have any other questions.
Thanks for the question!
Best Regards,
Mike Akard
Signwarehouse, Inc.
Technical Services Manager
