VS 420 Scan Motor 0040 error
Willy
After I complet the limit initialization, I restarted my VS 420 and now getting Scan Motor 0040 error. I think something out of time. Can anyone help me with this.
Willy
WooHoo!
This problem is solved.
After thinking long and hard and all the things I tried, My issue started when I accidentally got into Limit Position instead of Service Mode. I tried to a Limit Initialization one more time and this time it worked. All errors are gone.
I'm very happy that this problem is solved. Now to move onto the reason for changing the dampers. Printer has been setting for a long while, but I had the head soaking on the captop and periodically I would check it to make sure it didn't dry out. So I go to fire my VS-420 up and the print head is plugged up. so after two cleaning cartridges and a lot of cleanings, I decided to change the Dampers and 6 cartridges. Looks like the nozzle check is getting better.
