Vutek QS2000
BALLPARK
Hello All...
I recently purchased a Vutek QS2000 and waiting for tech's to install the printer.
I am using Caldera V10 for the RIP software and new to it as well. Turns out that Caldera does not have Vutek profiles for download. I will have an X-Rite system once the printer is installed to help dial in the printer profiles. I've never used one before and hoping to get some help with some profiles from current Vutek QS series owners as I learn to create my own profiles.
Can anyone help me out with any profiles for the following media types to use with Caldera V10?
Banner - 13 oz - Scrim
Banner - 18 oz - Double Sided - Scrim
Banner - 10 oz - Mesh
Banner - Curl Free - Pop-UP or Zeelon
Coroplast
Foamboard
PVC
Aluminum Composite Material (ACM)
Phototex - OPAS or Standard
GlassAdhere
Backlit Films
Static Clings
Calendared Vinyl - 3M or Oracal or Avery or Mactac
Cast Vinyl - 3M IJ180-CV3-10 & Avery EZ RS 1005 Supercast
Poster - Gloss or Matte
Thanks for your help and any thoughts that you may have to help with this process!!! :toasting:
Correct Color
Ballpark,
If I might suggest:
If you're new to the RIP, and to the printer, and you're going to try to cobble together profiles and profile-making techniques from here there and the other place...
You'll wind up spending a lot of time which you could better spend doing other things, and in the end, you'll really never know just how good your profiles are, and since profiles in this business are everything, how good your final products are.
On the other hand, I can make all of those profiles for you. Custom made in your environment to get every bit of capability out of your machine on every media at every resolution. It will print as well as it can possibly print. First print. Every media. Every time.
You won't need to do any "dailing in" once I'm done.
I'm also a Caldera dealer, so I'm certainly familiar with the RIP. I can set it up, set up your printer, and give you whatever training you need to feel comfortable.
Also I'll set up your color workflow, profile your monitors, and then you get free lifetime tech support for everything I've done from me.
It's a total package I call "Color By Correct Color" and it's what every single client gets.
Probably take two or three days given what you've outlined here, and I guarantee it's the best money you'll ever spend.
BALLPARK
Ballpark,
If I might suggest:
We are located in Radford, Virginia. Please PM your rates for training on Caldera and creating the profiles for the Vutek.
Thanks.
