Wasatch + Summa = double cuts
Discussion in 'RIP Software & Color Management' started by iladi, Aug 9, 2017.
  1. iladi
    iladi Member
    115
    Apr 23, 2007
    Romania
    Anything I want to cut in Wasatch 6.8 on a Summacut D120 cuts twice:
    it cuts one time, then returns to origin and start to cut the same path.
    The same file sent to winplot cuts fine.
  2. Split76
    Split76 Member
    160
    5
    18
    Sep 15, 2013
    FInland
  3. 2CT Media
    2CT Media Very Active Member
    2,416
    123
    63
    Jun 15, 2009
    Mesa, Arizona
    Are you using illustrator with a stroke?
  4. iladi
    iladi Member
    115
    Apr 23, 2007
    Romania
    no, I am using Corel.
    Since I upgraded to version 7.4 the problem gone.
  5. iladi
    iladi Member
    115
    Apr 23, 2007
    Romania
    this what I got in e-mail from Summa:
    Hi Adrian,
    The issue with the double lines is usually due to the design being exported to EPS, and having activated the option to use the outline of the lines instead of the center of the lines.
    Should you design with Adobe Illustrator, then make sure the option “Convert All Strokes to Outlines” is unchecked:
