What could it be?
Discussion in 'Flexi' started by Bubba06, Mar 29, 2019.
  1. Bubba06
    Bubba06 Just Somebody
    339
    101
    43
    Feb 13, 2005
    Manning SC
    Today, all of a sudden my grays aren't gray. My Mutoh started printing gray kinda pink-purpleish.
    I checked my profile, and it's the same one I switched to about a year ago, because of the same problem.
    Is there anything else besides my profile that could cause this color change?
    Flexi 12
    Mutoh VJ628
  2. Gino
    Gino Premium Subscriber
    32,266
    2,010
    113
    Jun 7, 2006
    PA
    Are all of your heads firing properly ?? Sounds like reds/yellows might be a little tardy getting to the vinyl..... if at all.
  3. Bubba06
    339
    101
    43
    Feb 13, 2005
    Manning SC
    Test print looks good, and all other colors look good. It's just my grays.
  4. Bubba06
    339
    101
    43
    Feb 13, 2005
    Manning SC
    [​IMG]
    That is supposed to fade from light gray to dark gray. The yellows, and reds look good.
  5. Bubba06
    339
    101
    43
    Feb 13, 2005
    Manning SC
    This is what it's supposed to resemble. lol
  6. bannertime
    bannertime "You guys do banners, right?"
    1,878
    438
    83
    Sep 8, 2016
    Arlington, TX
    Did you create the artwork in Flexi? Try making the grays a K only value, or pull down the other values.
    • Like Like x 2
  7. Gino
    32,266
    2,010
    113
    Jun 7, 2006
    PA
    Yep, that shoots a hole in my theory.
    • Like Like x 1
  8. IsItFasst
    IsItFasst Member
    313
    8
    18
    Jan 16, 2008
    USA
    Also make sure it is not using an embedded profile that can ignore your current profile.
  9. M D Gourley
    M D Gourley Member
    42
    30
    18
    Feb 2, 2019
    New Zealand
    ...has the lighting in your workshop been changed?....I get this color change when viewing Grey's mostly, especially under some older Fluro tubes or Tungsten based lighting...it looks Grey again when viewed outside under Sunlight.
  10. Jburns
    Jburns Active Member
    644
    115
    43
    Jan 19, 2009
    Denver
    CMYK versus RBG thru the RIP? Try sending as RGB file?
    • Like Like x 1
  11. Bubba06
    339
    101
    43
    Feb 13, 2005
    Manning SC
    Nope. Same Lights.
  12. Bubba06
    339
    101
    43
    Feb 13, 2005
    Manning SC
    Where would one check for this?
  13. Bubba06
    339
    101
    43
    Feb 13, 2005
    Manning SC
    I will give this a try.
