What on earth vinyl does this? holy %$%$
Discussion in 'Vinyl' started by gabagoo, Jan 14, 2019.
  1. gabagoo
    gabagoo Major Contributor
    5,517
    79
    48
    Oct 10, 2006
    Vaughan, Ontario
    I have stripped off 5 trucks for this company so far and this is the last vehicle... None of them used this particular red vinyl. It is a 2ml but I also think it is one of those types with the white back. You can see that with me using a steamer and a plastic blade it leaves 100% of a grey adhesive behind. This is going to be a long day!!!
    ps... I bet it is an Avery vinyl yuck
  2. DerbyCitySignGuy
    DerbyCitySignGuy Very Active Member
    1,033
    291
    83
    Dec 12, 2013
    Kentucky
    Yikes! That stinks. The only time I've ever seen anything remotely similar (lots of adhesive left behind) was a shop using non-wrap vinyls. No idea what brand it was. Usually with a permanent adhesive.
    Good luck.
  3. Moze
    Moze Very Active Member
    1,860
    88
    48
    Feb 27, 2012
    Dallas, TX
    Just a suggestion: get some plastic sheeting, spray the residue with Rapid Remover or similar, lay the plastic sheeting over it and let it sit. Do the same to the rest of the doors, then come back to the first and hopefully by then it will have loosened up enough to easily remove it.
    • Agree Agree x 4
    • Like Like x 2
    • Informative Informative x 1
  4. Luke Handford
    Luke Handford New Member
    15
    3
    3
    Jan 11, 2019
    Warwickshire
    Ouch!
    Maybe give a heat gun & some lighter fluid / adhesive cleaner a go?
  5. gabagoo
    5,517
    79
    48
    Oct 10, 2006
    Vaughan, Ontario
    getting the glue off is not a problem...the vinyl has a grey adhesive and is near impossible to remove without any heat or steam. Steam seems better than heat gun as with the heat gun the vinyl gets all gummy mixed with the adhesive and just moves somewhere else on the truck. I have one side and the rear done although it has taken 90 minutes so far...Glue will be another 20 minutes or so, then attack the other side.... I find it draining to do
  6. DerbyCitySignGuy
    1,033
    291
    83
    Dec 12, 2013
    Kentucky
    Didn't MacTac switch to a gray adhesive a couple years ago?
  7. shoresigns
    shoresigns Very Active Member
    1,260
    217
    63
    Nov 1, 2011
    Vancouver, BC
    Why do you think it's Avery? For one, Avery uses clear adhesive on virtually all their coloured vinyls.
    • Agree Agree x 3
  8. because when there is a glue problem, first on the list is check for avery...
  9. Solventinkjet
    Solventinkjet Merchant Member
    3,370
    575
    113
    Aug 2, 2011
    Denver, CO
    Wouldn't this be a perfect job for Rapid Remover? Spray, wait 60 seconds, wipe off and finish with soap and water or even just alcohol.
    • Agree Agree x 3
  10. jfiscus
    jfiscus Adobe Shinobi
    2,994
    183
    63
    Apr 2, 2009
    Cincinnati, OH
    I've seen old reflective do this. It's never fun!
  11. JERHEMI
    JERHEMI Very Active Member
    1,078
    6
    38
    Oct 31, 2006
    Chicagoland
    Looks like old Avery reflective to me! Avery reflective had (has?) gray adhesive.
  12. shoresigns
    1,260
    217
    63
    Nov 1, 2011
    Vancouver, BC
    I've never had an issue with Avery's removable adhesive products, i.e. all their vehicle vinyls.
    Obviously you're going to have issues if vinyl with permanent adhesive was used, or the super-strength adhesive that virtually all reflective vinyls use.
    Avery HV1100 used to have gray permanent adhesive. Now it's clear permanent.
  13. gabagoo
    5,517
    79
    48
    Oct 10, 2006
    Vaughan, Ontario
    The vinyl is definetely a 2ml product with a grey blockout adhesive. Must have been something the other shop who did it had hanging around as all other trucks re done this month only had a 2ml normal red.
    Vander....you need to remove the vinyl before applying rapid remover, which I have done on the other side and the rear...although you have to apply it about 3 times as the adhesive layer is pretty thick. Then one last spray to totally clear everything. Shop smells like a Tropicana plant.
    • Like Like x 1
    • Agree Agree x 1
    • Hilarious! Hilarious! x 1
  14. zillion29
    zillion29 Member
    31
    7
    8
    Sep 20, 2016
    Allentown, PA
    Some Avery 2 mil vinyls randomly have a grey adehesive. Spectra Red looks like the culprit. How old was that install? Maybe from the aborted Avery 800 Series days when literally everything they made was a disaster?
  15. Johnny Best
    Johnny Best Very Active Member
    2,590
    1,451
    113
    Dec 9, 2015
    buffalo ny
    That has got to be the worst job to do. Picking at vinyl and then getting the glue goo off.
  16. Gino
    Gino Premium Subscriber
    31,098
    1,643
    113
    Jun 7, 2006
    PA
    THIS..... all the way, then light a match. Run and duck.
  17. SignosaurusRex
    SignosaurusRex Major Contributor
    8,328
    352
    83
    Mar 7, 2007
    Washington State
    AVERY 900 series (and old 800 series) "Fire Red" and "Spectra Red", as well as FDC "Fire Red" have a Gray adhesive. They both leave the adhesive behind like that. The old SPARCAL that Avery bought out also had Gray adhesive on some colors.
  18. gabagoo
    5,517
    79
    48
    Oct 10, 2006
    Vaughan, Ontario
    Yup I think your correct.... Next to reflective, that stuff has to be about the worst to remove.
  19. datoshway
    datoshway Member
    125
    4
    18
    Oct 26, 2011
    Rhode Island
    Any vinyl will do that when adhesive promotor is used. Like Pro-bond.
  20. Bruce Mello
    Bruce Mello Member
    68
    11
    8
    Sep 11, 2018
    Long Island, NY
    I have seen several of my friends remove the old vinyl quickly by using a boat shrink wrap torch to heat up large areas fast.
    Then they spray down with Rapid Remover and it’s clean quick
