What Solvent Printable Vinyl is best used for round Stainless Steel Tanks?
stew1tx
Centex Wraps and Signs
Most definitely get a good permanent adhesive. UNLESS you are trying to do something like 55g drums, which we do then you need a perm cast with reposition potential and air egress. Most want to keep the cost down so look at ritrama and maybe matte do it holds ink better. But Avery has the best high performance calendared now. Think it is 2126. Keep in mind it needs to acclimate to your environment well before application. The sweat with temperature swings so expect to face moisture issues if less than desirable conditions. Hope this helps.
jrp3
We are doing eighteen wheeler cargo tanks. So the best option is to get a perm cast with reposition potential, air egress vinly? if so, What is the best vinyl for this?
