What tool do you recommend to contour cut Gatorfoam or/and PVC sheets?
Tony Rome
Hi I just got a good deal on some PVC sheets about 18x24 and I want to contour cut them into specific shapes.
What tool could I use, I do not want to do this with a hand saw, I want something electric I can guide it through.
Want to cut Gatorfoam, Cintra, PVC etc...
Would a dremel be the way to go or even a rotozip?
Sorry not much experience.
Thanks!
CentralSigns
Tighter curves can be achieved with scroll saw, you'll need a variable speed one. A jig saw and a fine blade is good as well.
bob
Thanks!
If you're doing them individually or just a couple at a time then a Cutawl. The tool that was specifically designed for this sort of thing.
If you're doing a many of the same pattern, then pad them and use a band saw or a jigsaw with a medium to fine down-cut blade.
This side of a CNC machine, these are the best solutions. Since you mention Dremel and Rotozip, I assume you're either an amateur or a cheapskate or some combination of both.
If you want to do professional work, get professional tools. Ignore this at your own peril.
marcsitkin
We use a bandsaw with a fine blade on gatorboard
Works well and requires less cleanup than a hand held jigsaw.
Bill Modzel
If they're large, a router by hand. If they're smaller, a router mounted under a table.
Just make sure that the twist of the cutting flutes "pull" the laminated print into the substrate and not away from it. So you need a different bit for each setup.
CanuckSigns
if you are making a bunch of the same shape, I would get a template made up from 0.25" MDF or similar and use a hand router with a flush cut bit, each one will be identical and will take about 30 seconds to do
Tony Rome
Bob, "not much experience" I think was pretty clear, haha.
Definitely not a cheapskate, I want what is right and a long term good solution.
Here is an example of what I want to cut...
A lot of what I do will be in the range of 15x15 and 5 different shapes that I always will use over and over.
helmets (15x15) multiple with template 50+
Names 15x5 custom special orders
HS Mascot or HS Logos 100+ (15x15)
I am totally unfamiliar with the tools and I want a good solution, not a get me by.
Also, if this same tool could cut Sintra.
Thanks,
Tony
Tony Rome
Wow, that's awesome, and a pic too, thanks so much!
Do they make a counter top version, lol....let me guess they do it's called a .....(tell me, I really don't know, lol)
Tony Rome
Ok, maybe telling you my budget was a good idea.
Under $500 or really $300 if possible.
This is something I am trying out, but even trying out I know I want something like the Scroll Saw, in other words not a hand saw.
I think I really like the scroll saw.
Will it cut sintra, PVC , and gator (with the correct blades)
Thanks so much everyone, I thin kI am close!
Scroll Saw will cut all kinds of wood, plastic, PVC, acrylic, gator, foam sintra, Cor-X.... pretty much anything. It also gets into some mighty tight places. I think MacGyver has used it on occasions.
Oh, and it cuts through fingers very quickly, so be careful.
Tony Rome
Hahahaha, your a trip Gino, I am going to get one today!
ilikespam9002
I always just use a variable speed jigsaw and do it by hand.Always looks good but have a guide either printed or with a vinyl border to be peeled away after cut and always leave premask on it till your done.im not sure bout the gator board i hate the stuff damages too easily.
ili..... welcome and...........
I think you're thinking of foamboard. Gator cuts like butter.
for what you have described below reproducing the same shapes in a variety of substrates with the budget you have the way to do it is with a router table with a pattern bit as has already been mentioned i believe...you will make a master template and then what i do is using double sided masking tape adhere the two pieces together and the bit traces the template while cutting out the new piece...easy and fast..and in your price budget.
Thanks,
Tony
