Where can I order the translucent back panel of a readerboard?
WhatsYourSign?
The wind caught the readerboard of a client of ours and it caused the back panel to fly out of the cabinet and break. (we didn't install them... Not sure if it was a bad install or what)
I'm trying to find a source for the translucent 4'x8' back panel that has the strips the letters slip into but haven't been able to find one.
Does anybody know where I can order these panels at wholesale prices?
Thanks in advance!
Texas_Signmaker
Very Active Signmaker
What Johnny said. You get a sheet of lexan and install tracks on them to fit your needs. Both can be found at your sign supplier.
Malkin
If it's the wavy "V-3" fiberglass type with flimsy track for flexible letters, then you can order that here: http://www.sssigns.com/
Otherwise if it's flat lexan, then as mentioned above, materials come from local sign supplier and you assemble it yourself. (or hire it done by another shop if it's not your forte)
Kottwitz-Graphics
Unless it's a narrow cabinet and you need pan form faces. But you can still get that at sign supply house as well, just have to order
firesignman
Mumpower Signs Bristol VA.1-800-368-5420 Ike is the Man!!!
