Which one goes first? Mounting or Lamination?
aaronchan
Dear all,
I'm trying to mount some back adhesive paper on regular foam board, then to laminate it.
But which one should I do first? Mounting or Laminating?
Aaron (Newbie on mounting)
aaronchan
Laminate first then mount
Just curious, any reason?
I have done both way but since I'm a newbie, both didn't come out too well.
But seems like the way you said creates less horizontal roller mark by some how.
How come? Is that because the back paper pressed on the foam board and created a horizontal line on it?
Aaron
Stormyj
Just another guy
Are you using a hand roller? Most companies have large hot/cold laminaters and laminate the material before mounting onto an substrate or equipment. I dont have a laminater, but use a big squeegee, or the one I made anyway. Works ok, but does have problems sometimes.
AF
Aaron
Laminate first, and practice until you get the process perfected. Roller marks means you are stopping during the process, don't do that. When you start the rolling action you must continue until finished or the piece is ruined. Your machine has manual pressure knobs, so your learning curve will be steep and expensive.
