Which vinyl to wrap speakers?
Discussion in 'Vinyl' started by Frosty, Aug 22, 2011.
  1. Frosty
    Frosty New Member
    7
    Hello. For my first vinyl wrapping project, I'm going to wrap some speakers I've recently built. I'm wondering which vinyl would be the best. The speakers currently have a high gloss finish to them so the vinyl will stick. I was looking at Oracal 651 since it is durable and inexpensive. However, i have also read that it may have a tendency to shrink or expand with temperature. I'd rather not use Oracal 751 cast vinyl since it is twice the price, but I will if i must. The speakers will be indoors all the time, but during the summer, temps can rise to ~80 indoors. Will this be an issue?
  2. Frosty
    Frosty New Member
    7
    Any particular reason? I don't doubt you, I'm just curious since I'm new to vinyl and I've read that people use 651 on vehicles that go through much tougher beatings than these speakers will.
  3. EricRamse
    EricRamse Member
    62
    Scuff up the surface before you apply the vinyl,gives the adhesive something to grip into.
  4. TheSnowman
    TheSnowman Major Contributor
    6,874
    27
    48
    Aug 28, 2007
    Indiana
    The people that use 651 on vehicles are the lowballers that refuse to do a job right most of the time. I suppose under crazy circumstances there would be a reason, but I'm not seeing it really.
  5. Frosty
    Frosty New Member
    7
    So I should just bite the bullet and get the 751? Perhaps there is a less expensive vinyl that will work as well?
  6. SightLine
    SightLine Very Active Member
    Quality cast vinyl is the way to go. Do you even have a sign shop?
  7. NEGD
    NEGD Member
    88
    Why bite the bullet... try the 651 and then when it doesn't work try the 751.
    More importantly, do you know the difference between the two?
  8. Flame
    Flame Major Contributor
    8,283
    6
    38
    Apr 26, 2006
    Vancouver
    Not that I consider myself a lowballer by anyone's terms, but I swear 651 lasts longer outdoors than 751. I had to re-do a 751 job not that long ago, and I have a tanker with 651 that's been outdoors for 8 years on a construction job site, that looks primo, doesn't even show shrinkage.
    Doesn't make sense, but I swear there's a little magic in 651.
  9. Frosty
    Frosty New Member
    7
    Yes, I do. However, wrapping speakers is an odd application and I was unsure about which to go with since the 651 has gotten good reviews in similar applications as 751. Since I am only applying on a flat surface and don't need the extra conforming properties of the cast vinyl, I thought I might be able to go with 651. Since it's advertised as being nearly infinitely durable indoors, I thought it would be ok. There are many testaments to 651 working well in heavy duty situations that far exceed my application. And for half the price, I am hoping to be able to use the 651. I don't doubt any of you; I just need to understand why I can't use 651 or why I should use 751, instead of just saying that cast is best.
  10. NEGD
    NEGD Member
    88
    Almost everyone here will give you different suggestions on why you should, shouldn't or otherwise. The best way to find out and learn is to try. Are you experimenting with your own personal speaker or selling this to a client?
  11. Frosty
    Frosty New Member
    7
    This is my own personal pair. Just finished building them a few days ago. They're all primed/sealed up and ready to go. I just dind't want to paint since getting a perfect matte finish with paint is darn near impossible without expensive equipment.
  12. signpost-boston
    signpost-boston Making America great, one sign at a time.
    568
    Jul 18, 2010
    Boston, Ma.
    when you say "Speakers" you mean the enclosure. right? i just had an amusing moment of somebody wrapping a pair of JL W-0's..
    love to see if the bass actually hits lower on those...
  13. Frosty
    Frosty New Member
    7
    Yes definitely. I can't even imagine what would happen if I wrapped the actual drivers...
  14. NEGD
    NEGD Member
    88
    Are you going to be selling custom wrapped speaker systems? Just think of it as an investment then, you can go with the better product and sell it without risk of failure.
  15. Frosty
    Frosty New Member
    7
    I'm not ever planning on making wrapped speakers for a living, yet. I just thought it would be a good starting point for me to learn how to wrap since it's a small project that won't be sold to a client.
  16. oldgoatroper
    oldgoatroper Roper of Goats. Old ones.
    1,753
    103
    63
    Jul 28, 2009
    Alberta
    Calendered vinyl will shrink -- always -- eventually. Its in the very nature of the stuff to do so because of the manufacturing process.
    If you don't want it to shrink, use cast vinyl. Simple as that.
  17. routierracing
    routierracing Member
    91
    Well 751 is going to be better but 651 probably will be ok for a few years since its all flat. When you say your using it to learn how to wrap niether of those are wrap vinyls so you're probably not going to be learning much but I can't fault you for not investing in the wrap vinyls for such a small job when you don't really need it.
  18. wildside
    wildside Very Active Member
    1,452
    14
    38
    Aug 28, 2005
    Kansas
    is the cost of 751 really a deal breaker? i mean come on:rolleyes:, the cost of vinyl is so small it can't really be that much a of a issue for deciding
    sounds like the people that pay 50 grand for a truck and putting a couple hundred bucks into some door lettering will break the bank....
    i say, since you are asking about wrapping the speaker boxes, i would say you need to use 3m 180c, it is designed for what you are wanting to do, wrap......
  19. megacab
    megacab Member
    244
    that's what i was thinking. just buy a yard of real wrap vinyl from your local fellers or wherever you shop and go from there. you can buy a 60"x36" piece of oracal 970ra in matte black for under $30. it'll give you a chance to see how a wrap vinyl with air release properties works. buying vinyl meant for signage or decals and then using it for something it's not designed for doesn't make much sense to me. you should get in the habit of using the right material for the job every time. it's gonna make your life a whole lot easier down the road.
  20. MikePro
    MikePro Major Contributor
    4,427
    93
    48
    Feb 3, 2010
    Racine, WI
    always use cast to make it last! (this white boy's got rhymes yo!)
    Go with Oracal 3551RA or 3951RA if you need to wrap curves. 3M IJ180Cv3 is my preference, but oracal is my next in line and still highly recommended.
  21. Custom_Grafx
    Custom_Grafx Very Active Member
    1,637
    2
    That's what she said.
    Sorry, couldn't resist.
    +1 to cast.
