Need Help White printing grey on LEJ-640
Discussion in 'Digital Printing' started by Souldar, Oct 21, 2020.
  1. Souldar
    Souldar New Member
    15
    3
    3
    May 22, 2020
    Charlottesville
    We recently bought a used LEJ-640. When I output the EPS file to VersaWorks and try to print white it turns into a grey color that is just like is what is on the screen but says it is RDG-white. We use Corel Draw so the manual doesn't help me much as it caters to Adobe. In Version 5 of VersaWorks I can get white only to print white but not in Version 6. Our local tech was dumbfounded and said he would research and get back to me but so far nothing. Any advice would be greatly appreciated.
  2. Sean@CedarHouse
    Sean@CedarHouse Printing Money
    31
    3
    8
    Sep 22, 2020
    Beaverton Oregon
    See if there is a difference between an EPS and a PDF. Sometimes those file extensions can change things up on you. Also, if you are designing in RGB, convert to CMYK before sending to VW. See if that makes a difference.
    Hope this helps.
  3. Joe House
    Joe House Active Member
    962
    213
    43
    Feb 5, 2004
    WA
    It should be RDG_White - use the underscore rather than a dash. It should also be a spot color. Do not convert to CMYK or RGB - other colors can be designed in other color systems, but White, gloss and metallic need to be spot colors.
    Good Luck
    • Like Like x 1
