Need Help WIDE Banding, Maybe??
Discussion in 'Hewlett Packard' started by Bubba06, Sep 17, 2020.
  1. Bubba06
    Bubba06 Just Somebody
    420
    123
    43
    Feb 13, 2005
    Manning SC
    I have an issue going on with Old Faithful.
    My L25500 seems to have started what seems to be banding. Very Wide, inconsistent Banding.
    I have replaced my printheads, I've tried different profiles, different media.....
    It seems to be mostly when printing green.
    I see it some in the lighter blues, but no where as bad as green.
    Test prints look great.
    What might the problem be?
    [​IMG]
  2. balstestrat
    balstestrat Member
    207
    28
    28
    Aug 25, 2020
    Europe
    Your image didn't quite come trough.
    I still suspect a printhead issue. You have a bad one in there that is acting up while printing.
    If there is any that look suspicious, warranty replace them.
  3. WYLDGFI
    WYLDGFI Merchant Member
    1,189
    91
    48
    Oct 27, 2006
    Linden, NJ
    Still have the issue if you go into a higher pass count or interlace? Our 850s were notorious for banding greens and blues like that.
  4. jfiscus
    jfiscus Map Wraster
    3,192
    239
    63
    Apr 2, 2009
    Cincinnati, OH
    That really looks like an image issue to me. Like the gradient is messed up or wasn't interpreted/converted correctly. Possibly spot color/transparency issue?
    Rasterize that image and print it again and see what happens.
    • Like Like x 1
  5. karst41
    karst41 Member
    146
    25
    28
    Nov 3, 2010
    Stone Mountain, GA
    Banding? Where?
    Printing looks Perfect!
    If your complaint is the Green, your problem is with the Art, and not the printer.
    Save the printheads that you have changed out
    They are probably still good or can be cleaned/recovered.
  6. Bubba06
    420
    123
    43
    Feb 13, 2005
    Manning SC
    I have tried higher pass, lower pass, higher, and lower resolution, all the same results.
  7. Bubba06
    420
    123
    43
    Feb 13, 2005
    Manning SC
    I thought that too was the problem, so I rotated the image 90 degrees, it still does it horizontally.
    If it were the image, it should have been vertically when I rotated.....Right?
  8. balstestrat
    balstestrat Member
    207
    28
    28
    Aug 25, 2020
    Europe
    Yeap..
  9. jfiscus
    jfiscus Map Wraster
    3,192
    239
    63
    Apr 2, 2009
    Cincinnati, OH
    I still believe its the image, might be colors out of limits/gamut going wonky.
    Try rasterizing it and see what you get.
  10. Bubba06
    420
    123
    43
    Feb 13, 2005
    Manning SC
    I just rasterized, and printed and got the same results.
    [​IMG]
  11. balstestrat
    balstestrat Member
    207
    28
    28
    Aug 25, 2020
    Europe
    Does it come out 100% like before with the issue at the same spot?
    For some reason the images don't work for me..........
    Edit. I saw the picture now. Yeap, still with my first guess. Printhead problems.
  12. Bubba06
    420
    123
    43
    Feb 13, 2005
    Manning SC
    It seems as though the color change in the green lines up exactly in line with the white.
    • Like Like x 1
  13. Bubba06
    420
    123
    43
    Feb 13, 2005
    Manning SC
    How about this.
  14. balstestrat
    balstestrat Member
    207
    28
    28
    Aug 25, 2020
    Europe
    I'll just repost. Printheads. Seems like cyan head to me.
  15. kffernandez
    kffernandez Member
    320
    5
    18
    Jun 26, 2010
    Philippines
    i have an L310, and i recently encountered a strange banding that looks similar to yours'. if you zoom in, you will see that the left image is affecting the middle image, and the middle image is affecting the rightmost image. all images have the same solid colored background. [raster]
    kelly
  16. Bubba06
    420
    123
    43
    Feb 13, 2005
    Manning SC
    I can clearly see it, and it does look quite similar, just different colors are affected.
  17. Bubba06
    420
    123
    43
    Feb 13, 2005
    Manning SC
    Have you figured out what the issue is?
  18. Gino
    Gino Premium Subscriber
    33,299
    2,325
    113
    Jun 7, 2006
    PA
    Could there be a problem in your signal getting through properly ?? Is it that exact green regardless of the file ?? What happens if you go lighter or darker with the same color ?? How about changing the size of the print ??
  19. Bubba06
    420
    123
    43
    Feb 13, 2005
    Manning SC
    Gino, it is with any green.... It actually seems to be in any color that has lots of Cyan. The lighter the color the worse it is. The darker the color the less noticeable, but its's still there.
    What I have noticed this morning is that it seems to be straight in line with all of the white.
  20. balstestrat
    balstestrat Member
    207
    28
    28
    Aug 25, 2020
    Europe
    Both of you could try adding Color Bars to the side of your print. And make them wide enough to warm up the heads (20mm or so).
    It can usually be done straight from the RIP.
