Will eco solvent ink cure if you don't heat it?
VL
Tried printing on some chrome mirror material today. It prints the ink perfect but after a few feet the material starts to come off the backer sheet and tunnel. If I turn the heat off will the ink cure and if so how long will I have to wait to in order to use my print? Or does anyone have a suggestion on a specific brand material that works without the tunnel issues?
hansman
Is the chrome material eco solvent compatabile?
If so I would use low heat for certain. Having said that I have tried printing on silver foil with eco sol and it just wiped off.
Snydo
It will cure with time, I've used low pre-feed temps, and pretty high platen temps with good results on chrome and reflective films on our solv & eco sol.
Heavy coverage can be rough to dial in on the chrome.
Best of Luck.
Cyw
RTape vinylEFX chrome, silver & gold are all totally compatable for Eco-solvent ink and it prints beautifully on my VC.
totally dry to the touch coming off the machine
absolutely no drying, smearing or tunneling issues.
splizaat
If you plan to CUT the vinylefx, good luck. Everything we've every cut on that material will literally curl completely off the liner.
kanini
We print a bit on the R-tape FX chrome with Roland eco-sol and we print, wait a few days to a week(!), laminate and cut. Works well but then we also don't cut right to the colours. It's very important to not cut near the colours otherwise it will curl like nothing else. We also use little to no heat to avoid curling, and it dries after a few days.
Typestries
Possible workaround-print on clear an apply the clear over the chrome. Works pretty darn well actually especially if you print onto an optically clear vinyl but regular clear might just suit your needs too.
