Window perf printing help ?
strycker
When I print on window perf ( classicvue ext ) I get these white swooping streaks through my print like someone took a 6in wide dry paint brush and wiped accross it . I have cleaned the decoder strip,done 2 cleanings, one powerful cleaning, nozzle check is fine. I am sorry but I don`t have A pictue of them because I kinda got A little upset and threw them out.
I have A Mutoh Falcon Outdoor 62, setting are ( 720 x720 heaters are at 45deg. front and back and the quality is set at med.
When printing on anything else, my prints come out just fine.
please help.
strycker
I thought the same thing , it`s been about a month since i`ve used it and It`s half gone now because i have used up most of the 100ft roll.all the previous print came out perfect. I called teck support ( signs wherhouse ). they told me it might be a heat problem
Thanks for your input mike
Capital Signs
Might be??? You need to be hard on them and say you need a definite answer. No sense in a maybe answer from signwarehouse... I would test their "new" customer support and tech support if they do say they have changed...
strycker
thankyou, they realy did try to help. I know alot of people have had some problems with signs wherehouse as have i in the past (my mutoh was sucking the magenta into the waste tank over night. After 3 cartrages of ink --200$---and numerous calls to signs wherehouse trying to get someone to call me back, one person--a verey nice lady said they would replace my lost ink, but later recanted on that one. Here recently they have been pretty helpful.
