Window Perf Tips
JLD984
Hi all, relatively new to applying window perf and having a lot of trouble with air bubbles. I'm using optically clear laminate which is scratching way too easily so I haven't been too keen to push that hard with the squeegee. Any help appreciated.
rjssigns
If there is nothing legal stating you need to use a laminate stop using it. We don't laminate any of our perf. Just gets sprayed with SW Kut-In clear. Over here there are a few counties/states that require it. Most don't AFAIK.
MagnificentBastid
If you have to laminate, then I recommend using 3M 8518 laminate instead of the optically clear. If you compare the laminates, you'll find them identical when it comes to how clear they are. However, applying some heat to the 8518 allows for some of the streaking and bubbles to go away.
