Windows 7 and Flexi 7.6
Discussion in 'Flexi' started by wes70, Oct 7, 2009.
  1. wes70
    wes70 Very Active Member
    1,592
    Oct 31, 2005
    Canada
    First off, I only use Flexistarter as a bridge program, as I design everything in Corel. I plan on purchasing a new 64bit computer as soon as Windows 7 is available. Will I be able to use my old 7.6 version with the new system?
  2. genericname
    genericname Active Member
    946
    Feb 27, 2009
    Canada
    From my understanding, 64bit support was added for WinXP in Flexi 7.7. It should communicate in the same way with 7 as it does with XP, but you're still one revision off. Also, this compatibility only applies if you have a USB hardware key, and not the old parallel.
    I gave Windows 7 a shot about a month ago, and the hardware key was the only stumbling block I hit.
  3. Steve Rife
    Steve Rife Member
    77
    Theoretically, the 7 version of the software will be supported under Windows 7 due to the XP emulation the OS will utilize. However, SA International will only fully test 8.6v2 with this system, so, any problems that may occur with the program will not get any technical support.
    If 7.6v2 works under 64bit, I apologize that I don't recall when it was introduced.
  4. wes70
    1,592
    Oct 31, 2005
    Canada
    Thanks guys!
  5. southshoredecal
    southshoredecal New Member
    16
    i have flexi 8.1 working with windows 7 RC no problems.
  6. javila
    javila Active Member
    847
    7.6 won't work on 64 bit windows. Once of the sub programs that flexi uses is 16 bit and 16 bit support has been dropped from 64 bit.
