Wireless Network Bridge
Tovis
Network #1) I have 1 wireless router thats on a network
Network #2) I have another router that is on a network
We are having to transport the files between the networks on a thumb drive.
I want to create a wireless bridge between the 2.
Would it work to turn on Internet Connection Sharing in windows vista and bridge the 2 networks from a computer on network 2?
oldgoatroper
Roper of Goats. Old ones.
best way to do this is to replace your non-wireless router with a straight switch, then plug it into one of the ethernet ports (usually 4 of them) on the wireless router.
Job done.
Also, you may be able to configure your current non-wireless router to act as a switch. Then just do as above.
signswi
Are they both actually functioning as routers, not just as access points? That'd be extremely odd, it would mean you have two internet connections (two different ISP connections).
choucove
First, do you need these two to be separate networks for any reason? Is that why they are running off of two separate routers? If all you're wanting is to make this into one big network, then the easiest thing and best thing to do is pull out one of the routers and just connect a gigabit switch behind the remaining router and plug all your computers into that switch. This way you don't have to go into the router settings and configure anything at all, it's just a matter of moving around a couple cables and is much more efficient than trying to do bridging.
