word .docx to Corel
Discussion in 'General Signmaking Topics' started by ocean502, May 30, 2012.
  1. ocean502
    ocean502 Member
    233
    1
    18
    Apr 29, 2008
    California
    Hi
    I have a customer that emailed a layout for a brochure created in Microsoft Word. I am having trouble importing, copying, etc..into Corel. I downloaded a doc converter that is not working. I am usually never able to import a pdf into Core. When I save as a jpeg in Word, it comes over pixilated. I have to adjust the background for the bleed of the brochure. Any advice??
    Susie
  2. markymarkmfb
    markymarkmfb Member
    115
    Jan 30, 2009
    Walled Lake, MI
    http://www.zamzar.com/
    Maybe this site will help you convert it to something you can use, it will convert to eps format. I've used it plenty of times with good results.
  3. J Hill Designs
    J Hill Designs Major Contributor
    15,549
    15
    I would first try to print to cutepdf or the like, and bring that into corel
  4. oldgoatroper
    oldgoatroper Roper of Goats. Old ones.
    1,753
    104
    63
    Jul 28, 2009
    Alberta
    This may or may not be of any help to you but...
    DOCX is really a zip file. If you need to get any graphics out of a DOCX file, simply rename the file to have a .ZIP extension instead of a .DOCX extension, then open the file in WinZip or WinRar or whatever and you will find folders to explore -- all of the images that have been imported into the document can be found here in their original formats (i.e. JPG, PNG, SVG, etc.)
  5. 300mphGraphics
    300mphGraphics Active Member
    518
    5
    18
    Aug 15, 2006
    arizona
    Have the customer save the file out of Word as a pdf instead of the .docx and send that to you.
  6. thewood
    thewood Very Active Member
    1,781
    Dec 28, 2005
    Tennessee
    This is a great tip that I picked up here on Signs 101.
    You may also be able to export the .DOCX file as a pdf via PrimoPDF or similar program.
